newbie pci overflow problem
Re: newbie pci overflow problem
yeah, maybe the originally slaved Pulsar One sneaked ahead and is trying to rule the system now... ;)
good luck, Tom
braincell
Post by braincell »
I bet if you take the old card out, everything will be perfect, also make sure no other device is using the same IRQ. Disable all things you don't need in the BIOS such as onboard audio etc..
yes, that would be a good idea to verify the source of the problem.
Just remove the Pulsar One and check if the required number of channels will then be processed - pure Asio doesn't need much DSP resources at all.
dradisf
Post by dradisf »
hey guys just reinstalled a new version of windows, from sp3 to a sp2 version and works flawlessly :) and also amazinly now my cpu was drastically improved in cubase.thanks
