You mean a smaller heat sink for the MCH?Neutron wrote:
If it happens to not fit because of the MCH fins, you can put a smaller one, because the big fan will blow on it.
CPU fan
Thanks for the tip Bill.
Yesterday I ordered from our local online retailers and this time they acted very quickly.
I expect to get the items in 2-4 days.
So for me at least the choice of processor cooler is made now: Scythe Andy Samurai Master (hah what a name!).
I have also a Nexus Case Fan 120mm Ultra Silent PWM just to have something to experiment with.
Next step will be the installation. It's interesting to see if Andy feels at home with my MoBo
Yesterday I got the Scythe Andy cooler.
It seems to fit, actually two orientations are possible. Maybe the best way is to have it with pipes facing towards the back of the MoBo.
I don't think there'll be any problems getting it into its place. I'll be away for a week so the real installation job will be done after that.
Cheers,
-k
Cheers,
-k
I've found opinions and links in this thread as an interesting starting point.
The subject becoming very articulated nowadays, I can see.
I guess the 45nm technology could bring some more change in the cooler area.
Further searching the web I've found this Scythe Shuriken, and I like it since its light weight and limited dimensions.
Going by what I've read on this review, It looks being pretty silent at low temperatures
(noise measurements by this site are taken in a soundproof enclosure @ 12'', NOT @ 1m as usual. An indicative value @ 1m can be obtained using dB2=dB1-20log(d2/d1), being d2=100 and d1=30.48 )
Considering then the heat dissipation of the E8000 series CPUs, I'm wondering if the Shuriken can be a good choice looking for a very, very silent machine based on a Wolfdale Core 2 Duo E8200.
What's your opinion?
i really dislike those big coolers.
if you're overclocking, they're surely a good idea, but for the rest of us...the main thing is that there's a lot of torque on the mounts, and the motherboard, the thing has a very small footprint and a huge, heavy head. it's very easy for one to become dislodged and the cpu and/or motherboard damaged. granted, in a computer that never gets bumped or moved, there's probably no issue there but....the stock cooler has never failed on me in more than 30 installations. the current one is quiet and more than sufficient.....
i'll STFU now....
i'll STFU now....
I've a Zalman CNPS 7700 Cu at now, since the stock fan of the Prescott was quite noisy. But the 7700 is large for my case, it practically gets in contact with the PSU fan grid which I had to remove.
Apart from this I wish to avoid the installation of 1Kg of copper on the new MoBo, although I never moved my machine till now.
The Shuriken is lighter than the stock cooler (355g) and just a bit larger.
It has PWM speed regulation like the stock one.
Does the stock Core 2 Duo fan really rotate at 1500 RPM? (max?) http://www.frostytech.com/articleview.c ... cleID=2132
It looks exactly alike the old version going by the pictures.
Different inclination of the blades or just different heat dissipation of the CPUs?
This table with data extracted from FrostyTech.com reports values for Scythe Shuriken, Zalman CNPS 7700 Cu, and Intel stock Pentium D and Core 2 Duo coolers.
In my system I have a rise of 22° - 23° C using the Zalman CNPS 7700 Cu with a Prescott 3Ghz (800 Mhz FSB) in idle state, and 44° - 45° C full load @ 20° C ambient temperature, but there's a 25 cm fan on the case side blowing toward the CPU cooler (at now it's manually speed regulated, but I'm experimenting with a circuit using a thermistor in these days)
- Coolers.jpg (86.82 KiB) Viewed 4207 times
Why that?garyb wrote:t.....i'll STFU now....
I installed the stock 775 fan with its clips just 1 time in the past; and the machine had thermal lock at the first startup. This because, following the instruction in the Asus manual, I installed the cooler with the MoBo already mounted in the case.
The pressure needed to lock the cooler was bending the board in a way I considered worrying, so it ended with one of the four feet inadvertently bad locked...
Then a friend of mine came to fix it (removing the board from the case).
Now, the Shuriken has clips like the stock one... I'm somehow worried for that...
stardust wrote:Wow I wouldnt accept any noise level beyond 20dBA and here the go 50+
http://www.frostytech.com/testmethod_mk2.cfmCochise wrote: (noise measurements by this site are taken in a soundproof enclosure @ 12'', NOT @ 1m as usual. An indicative value @ 1m can be obtained using dB2=dB1-20log(d2/d1), being d2=100 and d1=30.48 )
50dB @30.48 cm should be below 30dB @ 1m
Still high but...
I forgot to state the Zalman in my machine is operating at min speed (980 RPM)
The thing puzzling me is: they state 24.7° C above ambient. At ambient 20° it should be 44.7°. I've up to 65° and I'm sure I'm quite below 85W
ADDED:
No OC.
Just need an 'as silent as possible' machine.
Staying in a certain budget, of course.
If the heat is low and the MoBo can drive the Shuriken in the right way, making it turns at low speeds, it can be a very good solution, considering all the faces.
show a consumption lower than the official specs.
ADDED: Temperature values using a Zalman CNPS9700 LED
This tables from http://www.xbitlabs.com/articles/cpu/di ... fdale.htmlstardust wrote:... A 65W CPU should not need so noisy cooling
- dissipation.jpg (17.52 KiB) Viewed 4511 times
- FrancisHarmany
@ FrancisHarmany
Why not supporters?
@ Stardust:
You have a quite high case, I guess.
For sure 17dB is the lower noise standard at today, but the Coolscraper is 153mm large. I could only mount it blowing hot toward the PSU fan, or, maybe in the opposite direction, but it should stay stealing the air to the PSU fan...
Moreover it's just 213 g lighter than my old Zalman 7700.
ADDED: Sorry 153 mm is the height. Maybe I could mount it.... but I've different air flows in my case; I need kind of fan parallel to the CPU plane...
Why not supporters?
@ Stardust:
