SOLARIS 5.0.6
- FrancisHarmany
Hey Jimmy,
I was just listening to both versions, and to me, the first version is the best.
The second has too much treble and lost too much bottom.
Much of the power of the drums went down the drain....also from the synths.
The ideal is probably somewhere inbetween the two,
but closer to the first than the second, unless my system is misleading me terribly.
Cheers
Jörgen
Cheers
Jörgen
After a nice nap, I tend to agree.
Funny how your ears work better after walkin' away for a while.
I decided to use a compressor for the very first time in the virtual world. I remembered using the ancient hardware DBX of yore and must say, I can actually hear the results of the virtual one better.
Hardware compressors seem to require more back and forth tweaks to get it right, this one sounds and works quite well, and very fast.
I bring you the final tour, last mix,.....ladies and gentlemen the DAS 2A St.
Ankyu.
Ankyu.
Yo Bro,
I have no idea what the fuck I am doing, so do not take any advice from me.
I got some chops and some ears that's it.
I used VDAT to record.
SpaceF's FP106B mixer with his AUX Delay which has some sweet EQ's built into it.
The top recording used the DAS 2A St compressor in the Master Out Effect Insert, and the bottom recording ( # 2 ) used only the mixer.
I am just starting to learn. They are many more guys here who have much more experience than me.
I use headpohones and try to do as few tracks as possible since I lack quality monitoring facilities.
If this sounds good at all, it is only because of the tools that developers have provided.
I am buying some 5.1 Blue Sky nearfields for use in the future.
I am an example of a beginner who is blessed by the tools only. I can only imagine how much better this could sound once I know what I am doing.
