SCOPE X-ite still VIRTUAL?
Planet Z Announcements
lagoausente
Post by lagoausente »
What about the onboard RAM and the convolution idea? I would be a waste that such power machine that cannot use convolution.
It would be also a good new for the samplers.
petal
Post by petal »
yes, and granular effects, advanced delay effects etc..
I know we have some granular capabilities, but they are limitted compared to what you can do in fx MAX or PD.
kensuguro
Post by kensuguro »
awesome, hope this comes soon so I'd know how to upgrade my PC.
hifiboom
Post by hifiboom »
i think the newer sharc chips even have some special code optimizations for doing fast and quality convolution....
And its possible that convolution on the sharcs will sound better than calculated natively because of a higher precision the scope chips provide over native systems presision....
the native solutions for convolution did never impress me btw.
darkrezin
Post by darkrezin »
I'm not really sure what the point is of having convolution on SC cards. There are already stifling patents on dynamic convolution, and there are plenty of products that already specialize in doing it - Focusrite Liquid stuff and the original Sintefex boxes. Therefore I personally can't see any point in SC throwing dev resources at it.
hifiboom
Post by hifiboom »
its all up to quality isn`t it?
I think we all agree that scope processing, even simple mixing through the scope engine sounds better than natively.
In my opinion almost every scope algo reverb sound better than native stuff because of the higher quality filter and more prescision in calculation maths...
now convolution is an extremly heavy calculation based on many math processing steps and if there is a quality loss it will degrade the sound more and more while more maths is done...
now through the fact that scope is superior to any hardware with single process calculation its likely that also stuff like convolution sounds way better on scope than f.e. native solutions.
if you do a quick search over at gearslutz, the users that own a sony S777 convolution unit claim it sounds way better than any native convolution reverbs.
http://www.gearslutz.com/board/high-end ... 777-a.html
I have to say I never was a fan of convolution but my opinion was mainly based on the soundquality of native plug-ins.
native vstis did also never impress me much, yet still i am very happy that i have better sounding synths for scope. :D
So you cannot really say, we already have this natively or on a liquid mix.
The question should be more, if its possible with scope, how good would it sound?
From my experience with scope fx , its likely that a scope convolution would sound way more realistic and deeper and less dirty/unlean.
even if it takes much power and only few instances could be loaded, if the quality is way higher than native solutions or other ir stuff, it would be worth the effort.
darkrezin
Post by darkrezin »
I'm not really talking about native - I'm talking about sintefex realtime units, and the higher range focusrite liquid units that can also work real time. There are patents on dynamic convolution, and there are sooo many cost-effective native/almost native (liquid mix) solutions that I don't think it's really viable for SC to compete. I don't do the maths at SC though so my opinion is essentially futile.
lagoausente
Well, we still don´t know if will have onboard ram, and if will be posible convolution, or we anyone already knows?
hifiboom
Post by hifiboom »
interesting this announcement claims its based on TigerSHARCs.
http://createdigitalmusic.com/2008/03/0 ... #more-3121
It’s based on Analog Devices TigerSHARC DSP chips, offering 10x more processing power than their previous high-end Scope Professional card
lets see if its true.
yish313
Post by yish313 »
hmmmm!....
well, well, well ... it's press :P :D
I don't buy into the chip-part of the story
even more if you do a bit of number's magic with the 10
clock of original Sharc 66, new one 333 MHZ ergo factor 5
new Sharcs can do SIMD processing, resulting in twice the performance
multiply and you have those 10 times
(SIMD - means single instruction multiple data
the DSP can process more than one 'value' in a single operation)
hifiboom
Post by hifiboom »
yeah astro, that right,
it may be a press fault.
but normally the company(in this case sc) spread the press information.
but as mentioned in another place the normal sharc would have to be used 14-15 times on the xite-1.
The tigersharc maybe could deliver the same power with less chip count.
At the end its not that important which chip it is, as power x10 is simply power x10. :D
according to the 'hypothesis' above it isn't even 10 times... under arbitrary conditions ;)
it's the peak improvement achievable in theory - if an algorithm isn't very simd-compliant, you'll loose half of the performance in less than the wink of an eye :o :D
... the rest will be barely enough to run a project about two or three times the complexity of your former setup at 96 khz... :P
nah, I don't wanna to spoil the party (and a lot of stuff really benefits from SIMD, seriously), but plain numeric figures have only a limited relation to reality
you know, in soccer it's called ...entscheidend ist auf'm Platz... :D
(sorry I lack a catchy phrase for the proverb)
johnbowen
Post by johnbowen »
OK, just a few quick bits:
1) no tigersharcs
2) no fan
jb
spacef
Post by spacef »
3) there were 18 of them in the XITE at the musikmess :D
EDITED I removed pics that I intended for planetz core users only as a very sneak preview ;-) thank you.
Refrochia
Post by Refrochia »
hehe - like the look n sound of that! Thanks for the update :D
There are known knowns. These are things we know that we know. There are known unknowns. That is to say, there are things that we know we don't know. But there are also unknown unknowns. These are things we don't know we don't know.
hifiboom
Post by hifiboom »
simply awesome awesome awesome!
whats the max sync load per new sharc chip then? 7000? 8000?
or in other words: how many mhz does one of the new chips offer? 333Mhz, 400Mhz?
spacef
Post by spacef »
I didn't ask this in particular ...
Astroman may have an extra mission now :-)
spacef
Post by spacef »
New algos. What is new is in the sound.
- The compressor has a very natural "hardware like" curve on fast transitions.
- The Eq is totally new
- There is also a new Gate
- you can see a part of the 5.1 verb...
SC Insert effects
SC Insert effects
spacef
Post by spacef »
so XITE-1 is not virtual.... :-)
