A16Ultra - would Big Ben improve it's sound?
- Janni
- Janni
Yes, that's it!
Or 4 cables for all 16 ins AND outs.
Didn't want to confuse you...
Cheers,
Jan
PS: What kind of IO-plates do you have?
If you only have one Zlink-plate, you have two Lightpipe connectors.
That means you only have 8 ins and 8 outs. There's no way to use them as
2x8 ins.
If you want to use 16 ins from the a 16 you need to have an other IO-plate (or
luna).
So you have to buy clock, syncplate and an additional card / IO-plate if you
only own a ZLink-plate... That's expensive for the chance of getting perhaps
a little better results...
Cheers,
Jan
2x8 ins.
luna).
Purusha
Now you got me really confusedOr 4 cables for all 16 ins AND outs.
My Scope card has only 2 optical and 2 Z connections availble. How can I use 4 optical cables at the same time than?
I need to have a stereo IN and 16 OUT at the same time for my OTB mix.
God is the source of all sounds!
- Janni
Hope that makes it clearer!Janni wrote: What kind of IO-plates do you have?
2x8 ins.
luna).
- garyb
- Moderator
- krizrox
- wouterz
Re:
Did someone verify this? I have 5 digital devices connected to my Scope PCI system so maybe it's time for an external clock generator but only if I can keep using the Z-Links.garyb wrote:the A16 via z-link is VERY good.
Janni may very well be right(i'm sure he is), still, you might write to Ralf and verify whether or not the z-link connection and a syncplate can be used together with the bnc clock input on the A16.....
- garyb
- Moderator
Re: A16Ultra - would Big Ben improve it's sound?
well, you can always sync the A16 to z-link in any case. try it.
xite knight
Re: Re:
I can only speak for my xite-1 and my big Ben that's clocking 7 devices.wouterz wrote:Did someone verify this? I have 5 digital devices connected to my Scope PCI system so maybe it's time for an external clock generator but only if I can keep using the Z-Links.garyb wrote:the A16 via z-link is VERY good.
But I would be surprised if the pci systems are different.
I rely on my BB being the master, so I wanted to bnc clock the a16u to it too. I could do that but not in zlink mode.
So, I concluded that zlink only works with the clock that's "embedded" in the zlink transmission.
It's been a while, but I am quite sure that my scope (for xite) would run zlink mode only as long as scope was the master clock. Otherwise, no zlink operation, sorry.
I wish someone could prove me wrong. Then I would (re)buy an a16u at once to solve my i/o shortage
Cheers
- garyb
- Moderator
what is wrong with syncing the A16 via z-link?
why doesn't that work?
xite knight
As long as the topic is external clock generators, it won't work, because zlink operation demands the scope system to be the clock generator, not the clock slave.
Proviso: Again, this is how I remember the constraints before I sold my A16U. Someone please prove me wrong
Cheers
- garyb
- Moderator
no, the A16 Ultra can slave to Z-Link.
- wouterz
This thread is also about external wordclock sync and zlink:
http://forums.planetz.com/viewtopic.php?f=1&t=13639
When I buy some BNC cables I can try it out for myself. I have a Korg MR2000S that has wordclock out and I can connect it to my Scope system (with sync plate) and my two A16 Ultras and see if it works.
Gatam
ok, the A16 can slave to Z-link but ....garyb wrote:no, the A16 Ultra can slave to Z-Link.
Can the A16 slave to Z-link if Xcite or Scope cards are not set as master clock but slave to an external clock ?
(i think xite knight was talking about that and i would like to know)
Gatam
Oki just read the thread you point out and we just need to connect the Xcite and A16U wordclock to the master and the Z-Link connection should work ?wouterz wrote:This thread is also about external wordclock sync and zlink:
is it ok ?
