RETRO
arela
Post by arela »
Everything works splendid at least so far!
Really big,big difference from P4-2,55gHz.
hmmm - i was afraid it was so :-)
powerhippo
Post by powerhippo »
garyb wrote::)
Hi, me again!
Hmmmmmm my luck wasnt so persistent :(
After a few days of glory problems started again! :cry:
Sys is very unstabile,Nuendo3 goes down 2-3 times in a couple hours,
STS4000 shows "LOW MEMORY" after 3-4 loads of sample programs.
What I notise, without NUENDO switching on, STS working normally
and NO "low memory" after sample program loading (all 16 ch) but
with Nuendo............problems occur!!!!!!!!!!!
Uhhhhh.............I did Active sensing staff and more latency etc,etc............NOTHING :-?
:cry: :cry: :cry:
Can't believe, It seems somebody likes me from the another side :evil:
powerhippo
arela wrote:I need a upgrade too, do you sell your 2,55 :-?
Still on 2,4 :D - but at least i'm thinkng of upgrading :o
Dont upgrade, have a peace :(
arela
Post by arela »
Sorry to hear there was trouble ahead.
Do you suspect the hardware?
powerhippo
arela wrote:Sorry to hear there was trouble ahead.
Hmmmmmm I dont know :(
When you have DuoCore2,P5B,2gb ram etc...and you receive "Low Memory"
from STS,.........................that is quite bad :-?
Dont have to toomany mood for work anymore, somebody hates meee :evil:
Did you try to chat w/ Andre?
He seems to always have a powerful rig up and running.
My friend here in Las Vegas has the same DAW as yours and OC's it to hit the " sweet spot."
I have faith in it, but sharing the RAM w/ STS and Nuendo could be trouble.
Good Luck and keep us posted.
powerhippo
Sorry but I dont understand this RAM sharing things (STS-Nuendo) :-?
Do I missing something :( ? How can I solve this???
Please see up high :roll: , did already everythings correct and regular,by the
install,WINXP optimization etc.
Greetings
next to nothing
Post by next to nothing »
just throwing in a massive upgrade to my audio system;
I took my trustworthy daw into a rather risky operation today... Its been unchanged for oh-so-many years, and today i took the plunge:
Its based on a 266 mhz fsb motherboard and i wanted to experiment, so i threw in an XP2800+ 333mhz Barton.
I was a bit shaky as i adjusted the fsb up to 165x2 (330mhz) as my ram also is specced at 266mhz. but for the time being its stable as hell :D
now THATS what i call retro ;)
and for the record the former hunting dog was a xp1800+...
I love AMD, if it wasn't for them, Intel would be killing me with their prices.
I almost went with AMD as I remember their design in the earlier Alpha CPU's.
I like the way you upgrade Piddi. I plan on buying a set up where I can do the same.
Brotha' Man Power Hippo,
How many MB's of samples are you using w/ the STS ?
Does it give you a display of available memory left ?
powerhippo
scope4live wrote:Brotha' Man Power Hippo,
It was only 2-3 sample programs of drums Man, a few mb that is all,
and it shows Low memory, perversely :-?
i did a search for "low memory" on the sts forum and found this thread:
http://www.planetz.com/phpBB2/viewtopic ... low+memory
which suggested this:
"Systemmanagement/system/advance/.../Memory (sorry, some of the items I don't know to translate) from 'Systemcache' to 'Programs'. I have to test which affect this has on other applications"
i would suspect that there is a a program that is eating unused memory....
powerhippo
garyb wrote:i did a search for "low memory" on the sts forum and found this thread:
Ok, I will see what is happening, and report!
powerhippo
Hmmm already did that, nothing.....................I will trie to install scope 4.5 from
SonicCore.................and see :o
powerhippo
:o Unbelievable, it was KONTAKT2 :D :D :D
When I deinstall that Sampler, everythings working fine :) With it, STS problem
" low memory" occur!
powerhippo wrote::o Unbelievable, it was KONTAKT2 :D :D :D
the phenomenon is called memory leak and usually associated with bad programming style...
well, what else would you expect from that company... ? :P
Tom :evil:
powerhippo
Tom :evil:
Hmmmm I have been send e-mail to Native Instrument support and they should give me an answer on this, I hope :-?
powerhippo
I call up one friend of mine told me about this "memory leak" in WinXP SP1
so that I should to download Hot Fix for it!
Anybody have a Link, perhaps :) ???
install sp2? :)
