New rack PC - neew advice
- next to nothing
this is probarly the longest link you ever saw
http://prisguide.hardware.no/vis_katego ... bmit=S%F8k
Go to www.supermicro.com They use the best capacitors, resistors, SCSI ( Adaptec ). Also, they are perfect for audio as they have no extra worthless frills, just the meat and potatoes, ankyuvarymush.
Finally my quest for a 19" 4U rack audio computer has come to an end! I have bought a second hand Carillon AC1 on ebay. It came very cheap - the total is nearly the same as a standard 19" cabinet costs in Norway...
(It is a low spec Carillon though, (PIII/1Ghz/512Mb ram) but no other tham audio apps will be installed, so I think it will work fine with my 3 CW cards)
Neb
Neb
The carillon is a good choice if you have noise concerns, most rack cases I've come across aren't machined very well and will not contain noise - they are designed to be in a noisy server room environment.
You can put any motherboard in the carillon case whenever you want. They're very nice cases, but extremely heavy - probably not great for live use.
