Blue Series Drum Modules (mod 2&3) UPDATED 05/07/07
Shroomz~>
Post by Shroomz~> »
Hello,
here is an update to the Blue Series Drum Modules. It now comes in a single download containing all 10 modules.
- Added mod2/3 preset compatability.
- Added preset list on/off button to each module allowing individual presets per module.
regards,
Shroomz
hifiboom
Post by hifiboom »
thx shroomz
emphazer
Post by emphazer »
very nice!
thx a lot
irrelevance
Post by irrelevance »
Excellent :). Thanks
ElectronicaDub
Post by ElectronicaDub »
Thanks for you diligent efforts. And everything.
Chris
If you manage to pull off a ride cymbal, I'll crap my pants !!
These sound really good Shroomz,
Hat's Off As Usual,
mausmuso
What am I missing
Post by mausmuso »
Hi Guys,
I must be missing something here,
When I load the modules, there is no knobs!!
When I move a module, the jacks disappear!!!
Is there something I need to put in the DSP folder or what??
Luv to try these but.........
mausmuso
roy thinnes
Post by roy thinnes »
Hurray!
Feeling like Christmas (2010!)
Thanks Shroomz+Shark. Modular presets work perfectly!
Please don't beat me...but... I have...t-t-two and a half little...wouldn't say: complaints, just (little!) annoitations:
-the individual preset lists for both midi and gate versions look for the same preset file, which causes an error message like this
when you try to load the Sd-1 midi version (which must have a preset list different from the gate version). Of course you can load the appropriate file after clicking ok.
-please gimmie the bd preset list! (it's missing)
-when you load the td-1 (gate version) module, the sdk Mix3 module opens as well.
Anyway, your modules are great!
Shroomz~>
Post by Shroomz~> »
mausmuso, I guess you're trying to load these into the sfp routing window. They are modular modules designed for use in the CW modular synth shells. :)
Roy, thanks for the feedback!!
straight to your points.... have you tried creating a new preset bank for each module? After you've created your own preset bank & .pre file for each module they should work without errors on load. Also, the gate & midi versions of each one should have separate preset lists after you've been through & created them for each module. Just add an 'M' or whatever to the .pre file names of the midi versions.
I noticed the xtra module surface open (mix3), so we'll get that fixed for the next release. :)
Thanks again for the feedback & if you spot anything else, don't hesitate to let us know !!
regards,
Shroomz
roy thinnes
yes, I've created separate preset files for gate and midi versions (of course, since otherwise you'll get that error message shown above). But the midi versions look for the preset file with the same name as the gate versions (CP-1 Clap.pre, TD-1 Tom Drum.pre and so on); the modules don't "remember" that they have to look for a different preset file like CP-1Midi.pre.
Aah, have to check your new Random module instantly!
Shroomz~>
Post by Shroomz~> »
Ah ok, thanks Roy! I can fix that easily enough. It just means some renaming & to recreate the preset lists. I can't do it right now, but I'll get that sorted asap.
Ben Walker
Post by Ben Walker »
Hi Sharc & Shroomz,
I think the version of BD-1 that's in the download file has no preset functionality. Have a look at the images here. All modules have the preset button except the first.
Sorry if this is an already known issue (or if I'm mistaken).
Ben
Shroomz~>
Post by Shroomz~> »
Hello Ben,
Let's see what we can do to fix that !! We need to rebuild half of the preset lists anyway, so it wiLL get fixed !!
