PREVIEW: Rendered Virtual Analog DJ-Mixer
- hifiboom
- Shroomz~>
limiting the perspective would make the perspective false & less life-like. Making a device which fully displays this perspective with this amount of controls & elements (around 200 or so) would basically be a waste of resources imho. This is also one of the main reasons for questioning the viability & usefullness of devices which have different skin designs switchable via a button or whatever, becuase they'd be using resources without any reason other than 'look'.
stuff3d
Yes, mine is dreadful in English, it is translated by translator.
German I cannot write, everybody wants itself then excites.
if I can also understand.
I am also sorry this, however, does not go differently
Animationen are edged, must be only cut out.
As I am said on nobody fall on perspektive, Shades and Shine renounce.
If with 100 animationen does not go, is projekt to fail convictedly.
To me is also aware that this eats plug in if it should run very much Certainly
a lot dsp. I take this in shop.
But as said, this is projekt to see whether Such a thing is generally possible.
- sharc
It will be good to see how well it works. My guess is that it will give a lot of peoples graphics cards and cpu's a hard time but in theory at least it should work. My main concern with this plugin is the amount of screen space it takes up. 1600x1200 is just too uncomfortable on my display and I don't like the idea of having to switch screen res every time I want to use this plugin.
- sharc
stuff3d
No, do not stop!
Nevertheless, those iIdea would be able to In thus projekt Flow in!
I have it now also in took more than 100 animationen by Button pressure to cut out and to store away un'ter sequential namen with photoshop.
gott is thank! (gibt es den spruch überhaupt in englisch?)
and again further interv
have now only problem with animationen in sdk,
but now I could assemble this mixing-console.
- hifiboom
ds-sound
Looks great, excellent modeling!
See if you can improve the lighting a little bit, It's slightly too dark to my taste.
some mild and soft shadow casting could also contribute to the realistic appearance.
Blend Studios | www.BlendStudios.co.il
ds-sound
Man... what translator are you using??stuff3d wrote:I urinate in mine hose
all your base are belong to us!
stuff3d
Now, however, again to seriously Of life...........PFFFF
To me better likes if it a little bit dark is.
If irgens a little bit long time is bright, hurts me in my eye
I have darkened it rather something.
So has consciously liked Choice on darkened version..
But I think this is Taste thing.
And will not work on it any more because the animationen ones are ready.
ds-sound
- hifiboom
stuff3d
Animationen are almost ready.
Yes, this goes on moemory, and dsp. 10,000! pictures till present.
However, it runs astonishingly well.
I finish him now first thus.
Because of bad Shades animations and to some Crossover, I become 127 pictures again rendering.
Because this lasts very long, up to 3.5 h pic, I must wait too long to this is ready. then is able to one also about single fenster After think.
At the latest next week I will offer beta version, then one can look first like on 1600x1200 comes.
If with windows several want, this does Maybe.
however, I will work with that poured version.
What is a yoda-izer?
ds-sound
it is something that makes you sound like Yoda from star-wars.
