un freeze my computer, please
hmm, well you can't change the type or number of channels on the asio modules while cubase is open or you will get a freeze for sure.
are you using midi? if you have a controller connected, go to the "midi" menu in the routing window and put a midi monitor in the project. connect it to the pulsar midi source and tell me, are you seeing active sensing and midi clock messages?
danieldude
Post by danieldude »
when i dont touch keys i get the messege- active sns and when i press a note - it says note on and note off
danieldude
garyb can you xplain the diifrance between asio dest \source an asio2 source\dest
one set semms to work smoother , what r they? :roll:
check the I/Outs and Drivers section of the manual, it's deeply explained :-)
you need to turn off active sensing on your controller. it is filling midi buffers and causing freezes. if you can't turn it off on the controller, you will need a midi filter. an external filter would be better, but there is a filter in scope that should work. it's in the midi menu where you found the midi monitor. connect it between the pulsar midi source and the sequencer midi dest.
also, be sure that in the bios, "plug and play os" is set to "no" if that setting is available and that "apic" is set to "disabled" if that setting is available.
danieldude
will do!!
i think there is no option to disable pnp in my bios - ill check again - also i will check the epic.
if there is a midi proablem , how come it worked fine on my last comp? :) ]
thanks garyb
active sensing seems to make troubles on some motherboards with xp and cwa for the reasons i mentioned(midi buffer overflow). it's a common problem. you needed to fix that irq problem as well.
danieldude
hi garyb
there is no option in the bios to disable pnp nor the apic.. :(
the pepole from msi told me to clear cmos , and disable onboard soundcard.
this is so grrrrrrrrrrr frrrrrrrr!!!!!!
i didnt try yet the midi thing you told me, ill get right to it
danieldude
oh, and, what did you mean when you said that older bios can be usefull? :)
no, i said to have the latest bios version.
you really should disable the onboard sound if you're not using it, along with any other unused ports(serial, printer etc.).
danieldude
hi garyb
well 'i returned to my prev computer!!
the next one will be pre -calculeted.but ill be sure to visit this forum, its great!
by the way do you know anything about dvd drive proablems? :)
thanks -a- lot
ummm,
a little?
pm me.
