E=Mixsat C2 (Updated)
Planet Z Announcements
Janni
Post by Janni »
Just ordered it !!!
GREAT WORK !!!
:smile:
Jan
spacef
Post by spacef »
MixSat C2 is updated and benefits from some features implemented in another spacef mixer.
- 2 midi channels allowing 2*119 Midi CCs
- "pre" is added to the rec. channel: all inputs can be sent to rec.out.
- added second insert slot in the aux inserts (mainly to allow PEQ4 on any reverb, but also allows to chain several effects or effect racks)
- Corrections: track 9S insert was uncorrectly saved in presets, now fixed.
Please not that the midi integration goes further, as the new implementation is solid with insert fx parameters too (in a better way than it is without intervention).
Mono to Stereo channels: the "sat channels" are the same, but without the equalizer. You can use an equalizer either in the filter slots or in the mono or stereo insert slots (see FX tab). Also contains slight graphical changes, a complete renaming of the rec channels (especially for dual, post and pre).
Dsp fixed for all sync signal (takes less than a dsp. what remains is other functions such as modulation switches and so on).
I have a very clean mix done for a series trailer, but i will be able to publish it only when the images are done, which can take a little while as it is a 3d anime.
MixSat C2 Update is available for the following packs only
- BlackBox II
- BlackBox Fx
- MixSat
Use the refresh button of your browser if you do not see the update link.
Repack of BB2/Fx etc will not be done before the release of some other mixers&devices later this year.
Tau
Post by Tau »
Many thanks for this new update, Mehdi! The Blackbox II has become my tool of choice for all my music, not only because of the unusual and customizable sounds, but also for the incredible GUIs... I'm using the mc2 mixer, Bi-Osc and LBH, as well as Echo 35, Slapback delay... If it weren't for John Bowen's Pro-Wave and ModIII (both often loaded with your Oscs and filters), it would seem that all I ever knew was the Blackbox... Excellent work, wishing you the best of luck for the future!
T
