Hello !! and Help!!
Debussy
Post by Debussy »
Ok, this morning I have changed Nuendo for Cubase (I tried this a few days before and I had the same problem), and the system seems ok. Why now?
I haven't done anything. The system and the configuration are the same.
Tomorrow I'll test cubase looking for problems. I hope there won't be problems...
Thank you for all your answer!!!
Debussy
Post by Debussy »
Ok, Yesterday, my computer restarted in four times with cubase, but the whole of time it seemed be ok ( I worked a lot despite this four errors) We'll see how the system runs today...
Debussy
Post by Debussy »
Ok, Today Cubase have gave me only a restart. I have could work a lot. But when I charged the STS 4000 a message sais me " error in DSP file KGparam3 vxd, check the installation". Of course I Looked for this file in C:, and the installation disk: There isn't any file called so! How can the system use this file if this file isn't in the install disk? I look a file called Kgpar3.vxd in the disk, but ovbiusly it's not the file.
Debussy
Post by Debussy »
The Motherboard, yes. Creamware support has recomended me Chipset intel 915 or 925. My motherboard is a gigabyte whit chipset i865pe (I think, I have to see it). Must I to change my motherboard?
Casper
Post by Casper »
Can you tell something more about your motherbord features?
HT technology (check in BIOS)?
How many USB slots does it have (check in BIOS).
And about your OS?
In what state is your computer system -> 'Standard PC' or 'ACPI'?
(see :Configscreen/Device Manager/Computer)
Other pci cards installed?
cheers,
Casper
the 865 chipset is very good with the cwa cards. yours could be faulty, however...
i'd check the meory and if it tests good(memtest), then i'd replace the mobo as the one you have is only about $90 to replace...of course, a reinstall wouldn't hurt either(format and reinstall)...
first, as Casper asked, what is your config?
what exactly are your irq assignments?
<font size=-1>[ This Message was edited by: garyb on 2005-08-31 13:13 ]</font>
Debussy
Post by Debussy »
Here you are:
GA-8IPE1000
CPU:
Socket 478 for intel micro FC-PGA2 Pentium 4 processor
Support Intel Pentium 4 (Northwood, Prescott) processor
Suport Intel Pentium 4 Processor with HT tecnology
Intel Pentium 4 400/533/800 MHZ FBS
2nd cache dends on CPU
Chipset:
Chipset intel 865PE Host/AGP/Controller
ICH5 I/O Controller hub
Memory:
4 184-pin DDR DiMM sockets
Support Dual Chanel DDR400/DDR333/DDR266 Dimm
Support 128MB/256MB/512MB/1GB unbuffered DRAM
Support up to 4GB DRAM
I/O Control:
ITE8712
Slots:
1 AGP slot support 8x/4x mode
5 PCI slot support 33 Mhz and PCI 2.3 compliant
On board IDe:
2 IDE bus master (UDMA33/ATA66/ATA100) IDE Ports for up to 4 ATAPI devices
Support PIO mode3,4
Serial ATA:
2 Serial ATA Connectors (SATA0/SATA1) in 150 Mb/s operation mode
Controlled by ICH5
On-board peripherals:
1 Floppy
1 parallel port
2 serial ports
8 usb 2.0/1.1
1 Front audio conector
3 IEEE 1394
1 IrDA connector for IR/CIR
Hardware monitor:
CPU/Power system Fan Revolution detect
CPU/Pwer system Fan Fail Warning
CPU Overheat Warning
System Voltage Detect
On-board Sound: (it's not interesting)
On-board Lan: Build in marvell 8001 Chipset (10/100/1000 Mbit)
1 RJ45
BIOS:
Licenced award BIOS
Support Dual BIOS/ Q-flash
Support Multi language
Support Face Wizard
Aditional Features:
STR(Suspended to RAM)
AC Recovery
Support @BIOS Support CPU Smart Fan Control function
Overclocing:
Over voltage (DDR/AGP/CPU) by BIOS
Over Clock (DDR/AGP/CPU/PCI) by BIOS
Sorry, It's too large :grin:
yes, that's the info for the mobo itself available on the webpage. what is YOUR configuration and what are the actual interrupts,or more specifically what is being shared?
for irq info go to start/programs/accessories/system tools/system information.
Casper
Post by Casper »
Ok , but it helps a little.
How many of the 8 usb ports are you using.
If none , shut them down in the BIOS.
If using 1 , try shutting down 7 of them , and find out wich one still operates.
When I just got my mobo , I too had these anoying restarts.
If your not realy into IRQ stuff, I recomend shutting down all ports that aren't being used. I just know you don't have 8 devices on you USB . So that's a start.
Then perhaps your parralel port (lpt1)
And even the Com ports if your not using them. Disable it all in BIOS.
Then if you still got it. You HAVE to look up in your motherbord manual wich physical pci slots are sharing the same IRQ.
Then you'd be able to give your pci cards a single IRQ.
Well, try these things, and let us know what happended.
good luck,
Casper
<font size=-1>[ This Message was edited by: casper on 2005-09-01 13:14 ]</font>
Casper
Post by Casper »
"On-board Sound: (it's not interesting)"
.....but it is.
shut it down in BIOS :smile:
Debussy
Post by Debussy »
Finaly, problems with restarts seems go out, but error messages about kgparam3.vxd file continues. Do you know anything about that?
Thanks for all your answer.
Debussy
Post by Debussy »
Ok, I'll do that.
I wish my next post will be in the music section :grin:
Thanks for all your help.
pranza
Re: Hello !! and Help!!
Post by pranza »
maybe too late, but...
there is a file KGPar3.vxd and the error refers to it.
the file is located in /Scope/App/Vxd.
the problem is, that file has strange attributes - 'hidden' and 'system'. you can unset them with command line < attrib "filename" -h -s > or to copy over KGPar3.vxd from installation disk manually and then you got file without attributes.
do the same for all files that has -h- and -s- attributes - overwrite them from installation disk that these attributes are gone.
i guess it is the scope bug with ntfs file system - i got these problems with several systems!
next to nothing
Post by next to nothing »
Another jobb for the famous Valis Batch File
http://forums.planetz.com/viewtopic.php?f=13&t=18596
I fixed that topic too btw...
