I might give the card another try, without Scope. I think I perhaps would be better using a dedicated pc for my Scope, then use Wormhole or Teleport or ADAT for getting scope things into main DAW.
@AndreD im interested to make the same setup. Can you tell more about your setup?
1) mobo is ok.
2) Processor- which one?
3) RAM- is it kingstone? Did you install 2GB ram?
4) VGA is ok
5) Hard disk- why you select Parallel ATA? Isn’t it SATA is better for audio?
thanks
But I have ordered Matrox P650, it should have been here today, but it is delayed.
So I am going to test again.
After all, this is the best cpu I have!
I am however more and more considering putting my Scope Pro, 2x Pulsar II in a separate pc, just to make the environment perfect for them, then I have 27DSP´s....
I´m wondering of getting the breakoutbox for my Luna II, and put that in the main DAW.
Anyone used CT-479 pentium4 mobile adapter on any of these boards with scope cards?
Asus P4GD1
Asus P4GPL-X
regards,
Jim
Asus PC-DL delux
Winxp Pro sp1
Nuendo 3 / mLAN
Gigastudio3
Native Instuments Komplete 2
2*xeon 3.06ghz
2gig ram
wd raptor 74gig system
wd raptor 74gig audio
Scope pro 30dsp (stand alone pc Asus P4GPL-X, Win XP sp1)
<BR
I have a Pulsar 2 and a Scope board. When I used these boards with Abit IC7-MAX3, I encountered a problem when I used the USB 2 ports. The system just hang.
Now I am gonna use a Asus P5WD2 Premium motherboard. Are there any out there that know about any known problems around this?
