problem with itunes on pc
:smile:
blah blah blah XP blah blah OSX.
problem solved, case closed.
Quicktime eh? This makes me think...
Its possible that your latency settings (for wav) in the Creamware control panel properties was set too low. Its a slider and its a bit buried--to get to it you need to go into device manager and/or the 'hardware' tab under "sounds and audio devices" in the control panels. Bringing up properties for your Creamware card (any card installed will do) will allow you to set the maximum number of software midi drivers available and change the WAV driver's latency, among other things. Most apps never seemed to have a problem with this but Quicktime always had problems (so did shoutcast recording) until I finally remembered to adjust this slider. Note that this may not be good for SONAR users still trying to use the WDM kernel mode drivers...(not sure about that though...?)
Kalinski
Post by Kalinski »
mate you are a star i have been trying to work this out for ages!!!
cheers
geoffd99
Post by geoffd99 »
THANKS just had this same problem fixed after looking here.
On my QT, I have to check the Wave Safe box too, Creamware was my default (in Control Panel) but it needed that checking.
Now I can play Madonna on my PC!!!
<font size=-1>[ This Message was edited by: geoffd99 on 2005-12-21 04:20 ]</font>
geoffd99
Re: problem with itunes on pc
Post by geoffd99 »
I have set QT already for P2 & still get stuttering, distortion, like a sine wave doing it, usually after an hour or so; relaunchig it fixes it for a while. Sometimes it is OK all day. I have not set auto start QT.
I have just set the latency to be same as ULLI (25ms). It was 33ms. If works, I will not edit this post!
