Example: Would the latency of an O2R also be determined by the amount of FX / plugins, or has Yamaha thought of some sort of standard latency for each channel despite the amount of fx? A highly respected digital desk like the Yammy shouldn't have variable latencies per channel I guess, otherwise you would encounter timing problems in the end.
I mean, suppose you have an EQ and gate on the first two channels, a noisegate on the third and a reverb plus flanger on some other channels, I would expect that processing channels this way has to deliver different latencies, or am I wrong ?
cheers
Ronald
P-IV 3Ghz pc/Pulsar II/PowerSampler/Luna II/2xbreakout box/Logic 5.5.1/Logic Control/Yamaha CS1x/Emu E6400Ultra/Waldorf Rack Attack/Nord Rack2
Dust collectors of the month: Casio CZ101/Korg poly800/Korg DW6000
<font size=-1>[ This Message was edited by: RoonSmits on 2004-12-13 12:38 ]</font>
						Has Behringer gone quality ?
				splitpoint
				time_chase
Even a single EQ or filter could cause phasing I imagine: take a LPF, made to counter changes in the signal. Resonance adds more delay, isn't that a feedback loop that, within it's wavelength set by cut-off freq, is fed back to the dry signal? Different types of filters and EQ's (compared the ones in Waves series to each other) function differently and also affect the phase differently. How would it be with analog EQ, let's say on a mixer table?On 2004-12-13 12:35, RoonSmits wrote:
Other effects, like a phaser, work on delayed signals mixed with the dry. On a phaser, the time is modulated so the interference works on different wavelenghts usually according to an LFO.
Luckily, the samples delays on our system are not LFO modulated
