VM-1242 .. no longer available
musurgio
mixer
Dear Shrommz,
Sorry for the many suggestions here but I hope these are the best of all of us !
Could you please also when link is activated then the insert effect become STERO ?!!
So that we could put a stereo effect like limiter across the linken channels.
That would be fnatastic feature !!
Regards,
Dimitrios
Regards,
Dimitrios
rodos1979
- Shroomz~>
Musurgio, you're suggestions are always welcome. We've been thinking about the issue with the insert slots since we added the stereo link functions & I think we have solution.
You're right about the input gain parameters, they would be better linked as well.
Keep the feedback coming, you've all been a great help so far.
- hifiboom
- Shroomz~>
musurgio,
we've got too many other devices to get finished before starting anything else, but to answer your question, more multichannel adders aren't too difficult to make.
hifiboom,
- the aux sends are already set up as 2 pre, 2 post.
- the inserts all work fine here apart from ch1&2 pre inserts being round the wrong way, which will be fixed.
- the aux returns can be fed to the mix or either of the busses via the corresponding buttons above & below the 4 blue capped faders (just like the 12 channels). Make sure you switch the aux's ON dsp by engaging the button located between the aux 1 send levels & aux 1 return EQs. When you hover over that button a pop-up description of the buttons function appears. There is a small bug in the led meters for the returns which we'll fix.
regards,
Shroomz
hifiboom,
regards,
Shroomz
- hifiboom
- Shroomz~>
Hifiboom, quote from the first page of the thread >>>>
Anyway, yes that's correct regarding the sends. Both pre aux sends are mono (sends 1 & 2) and both post sends are stereo.
Must be old ageShroomz wrote:The buttons at the bottom beneath the faders (with the green text) switch the channels, aux's & busses on & off the mix.hifiboom wrote:I can route to the group busses but the sound is still routed to the main channel ( so it gets doubled/phaser)
- hifiboom
- kensuguro
voidar
- faxinadu
ya this sounds goodvoidar wrote:Shroomz:
I've been thinking. Could you do a channel strip based on this mixer? Just the drive, EQ and fader. Mono/stereo version.
Perhaps even a valve compressor further down the line..
Or even expand the EQ to have two sweepable mids.
Of course, only for the channel strip device. That would rule.
http://www.oceanswift.net
Music
Music
- Shroomz~>
Sounds good to me too, the only issue is that I think MCCYRANO might have mentioned on the forum somewhere that he had a built a nice tube/valve compressor, so we could wait to see if he releases itfaxinadu wrote:ya this sounds goodvoidar wrote:Shroomz:
cheers!!
- hifiboom
Shroomz just a question....
if you take out the complete ECC tube stages, how much DSP power will the mixer need?
An untubed version may be a good replacement for the STM16/32 mixer?
if the ECC tubes take much power you could blow it up to a 32 channel untubed mixer...
hehe
This thing has true stereo sends, while the STM only has mono sends...
+ its really handy to have the EQs right there available for usage
hehe
voidar
Yeah, I think I read that tip he shared in the forum a while back. Sounded somewhat like a proposition. Anyway, he did do a tube EQ too. Can't have enough of anything reallyShroomz wrote: Sounds good to me too, the only issue is that I think MCCYRANO might have mentioned on the forum somewhere that he had a built a nice tube/valve compressor, so we could wait to see if he releases it![]()
cheers!!
My main point though was just a channel strip from the mixer in its own device.
