The device will work at 44.1 & also at 48 on some systems. I hadn't tested it at 48, as I thought there wasn't enough space on the dsps when using the dsp locked versions, but in fact it will work at 48 on our 14+6+3 card system & as voidar reports, it might also work at 48 for some 6 dsp card owners, but I'd imagine you might need a second card as well as a 6dsp one.Loshmi wrote:Shroomz, I made mix in 48khz project, with 0.1 version, no DSP management. Can you confirm this that device is working on 44.1, please. I am a litle confused about that....
As I mentioned in a post above, there's now v0.6 releases of all 3 versions which have different dsp management, so try those. I'd try the board0&1 version first as you have 2 x 6dsp cards.
