Scope 7
Planet Z Announcements
Re: Scope 7
Post by JoPo »
Peter4724 wrote: Presonus Studio One 3.5 and Harrison Mixbus 32C v4.
All programs now OK with Scope V7 ASIO (also Mixbus with Portaudio).
Wow ! This is very great news ! I'm going to try Harrison Mixbus, I think.
Peter, did you do like shayart, copying the 7.0 dsp files and overwrite them in your Scope folder ? Does it still crash ?
Peter4724
Re: Scope 7
Post by Peter4724 »
I have V7 reinstalled clean and then the dsp, sys .. files from DAS, Orbitone .... copied. The Legend and Master it EQ crash Windows. I will try a different method tonight.
Re: Scope 7
Post by JoPo »
Peter4724 wrote:I have V7 reinstalled clean and then the dsp, sys .. files from DAS, Orbitone .... copied. The Legend and Master it EQ crash Windows. I will try a different method tonight.
Apparently, there are DAS dsp files in Scope 7.0 installer and maybe some have been updated to work with Scope 7. Maybe you could install Scope 7 on another computer, then copy dsp files on a usb stick in order to overwrite them on your Scope computer dsp folder.
I tried to extract the files from the Scope 7 setup with "Universal Extractor" but it was not able to do the job ! So I did like Shayart : I installed it on an old laptop and copied all the Scope 7 folder to keep all those files somewhere. Just in case...
faxinadu
Re: Scope 7
Post by faxinadu »
readymedia wrote:Hey, there!
May some one tested it with ADERN FLEXOR 3.0 ???
Thanks!
yes, extensive testing. works.
http://www.oceanswift.net
Music
faxinadu
Re: Scope 7
Post by faxinadu »
Liquid EDGE wrote:
faxinadu wrote:
garyb wrote:as a general rule, never overwrite newer files with old.
that! can't be stressed enough.
Your installers for your plug ins. Would they overwrite files of the same name if it was newer?
It’s not possible to manually install your devices?
there are no extra dsp files with our plugins other than new ones, so you should be good to go. i have installed all our stuff and everything is fine :)
Music
faxinadu
Re: Scope 7
Post by faxinadu »
btw some small tease - i'm working hard to get us device naming on routing window for next 7.x :)
Music
shayart
Re: Scope 7
Post by shayart »
That's what I did
That's what I mean in my post before.....
I uploaded the dsp files in Scope 7.0 installer it to my dropbox....
link
https://www.dropbox.com/s/kw6dew3idc0g8c6/Dsp.rar?dl=0
It should help.... :wink:
Rebu
Re: Scope 7
Post by Rebu »
Yeah! just bought and waiting for the code..
Re: Scope 7
Post by JoPo »
shayart wrote:I uploaded the dsp files in Scope 7.0 installer it to my dropbox....
link
Brilliant ! :)
enantiodromia
Re: Scope 7
Post by enantiodromia »
hey Faxi , so your part of the dev team now?
big congratulations to you , you deserve it for sure !
faxinadu
Re: Scope 7
Post by faxinadu »
enantiodromia wrote:hey Faxi , so your part of the dev team now?
not officially but with lots of love :) i'm just enjoying the ride down the rabbit hole. i don't even consider it helping, since its a pleasure and honor and at the end of the day i make my music using scope :) fernando and i have an excellent relationship with holger and for sure as time passes we are able to offer more as the relationship and our skills and ideas develop. every day is still learning and experimenting.
at the moment outside of ocean swift stuff i'm working on those tweaks i showed in the above screenshots and some mods to scope devices and was doing a lot of testing in the days before v7 came out.
Music
tgstgs
Re: Scope 7
Post by tgstgs »
nice to see progress
good vibes
readymedia
Re: Scope 7
Post by readymedia »
@Adern
@faxinadu
Thanks!
me, M6700/i7quad/Win7: PT11/Ableton/Komplete
WinXP/Luna2/Modular2 @Dell630 Dock
the19thbear
Re: Scope 7
Post by the19thbear »
So cool to see that the platform is alive! I hope it stays alive for a long time, this time:)
Now, "all" we need now is a cheap entry level card, and osx support. Just minor tings, i know;)
But seriously, i think a cheap entry level card would generate lots of new users. The current solution isn't for everyone to test out.
Cool! I will be looking the next couple of months for sure!
Re: Scope 7
Figures it’s ready now.
I’m on my first non Scope gig since 2007.
Acoustic grand, Hammond B3, and a real 9 piece horn section.
I return after New Years and can’t wait.
I could barely play the Piano.
It took a week of choking before I could feel comfortable.
My reward will be Scope 7...
Ankyu
Re: Scope 7
the dsp files thing is nothing!
just DO NOT overwrite newer files with older files.
simple!
Peter4724
Re: Scope 7
Post by Peter4724 »
first attempts by last night.
1. Scope 5.1 84 bit backup (all plugins are working properly)
2. Clean Windows 10 64 bit installation
3. Installation Scope v7
4. Copy all original DAS dsp, sys files from Sonic Core page into the right folder.
5. THE Legend and Master It EQ crash Windows. (DAS coef11 .sys)
second attempts last night.
1. Clean Windows 10 64 bit installation
2. Installation Scope v7
3. Copy all DAS dsp, sys files from old Scope 5.1 installation into correct folder.
4. THE Legend and Master It EQ crash Windows. (DAS coef11 .sys)
third attempts last night.
3. Copy all dsp, sys files from old Scope 5.1 installation into correct folder.
4. Installation again Scope v7
I give up
Re: Scope 7
do you have the correct version of DAS coef11 .sys?
there is a 32 and a 64bit version.
Re: Scope 7
Post by JoPo »
Wow ! Peter, did you reinstall windows each time ? I'm not sure it helps.
Well... Backup your dsp folder, then delete it, then copy the dsp folder I made. It seems to be clean for Scope 7.
Dsp.rar
(6.62 MiB) Downloaded 417 times
I added all third part dsp's I collected since years + all new Scope 7 dsp's overwrited those that was older. Maybe there will miss some rare files but you certainly have them.
Peter4724
Re: Scope 7
Post by Peter4724 »
garyb wrote:do you have the correct version of DAS coef11 .sys?
For sure :(
