VM-1242 .. no longer available
Dear Shroomz,
I am very impressed with your work! This mixer sounds realy exciting! I tried only the first version without dsp management and made some simple mix with drums, and it was very, very hot. Is there any hope for user like me who have two Pulsar II and one Luna board (15 DSP in total) to try newest version?
Best regards,
Loshmi
Best regards,
Loshmi
The first version which loads on two boards won't load at 48KHz. I guess it won't load on an 14/15DSP card at that rate too. On a nother note, the previous version wouldn't load on my system at all
I am starting to appreciate processing in 48KHz and feel the standard EQs and distortion sounding better.
Shroomz: Any chance you ever will have this load at higher sample rates?
Did you notice this takes less DSP's than previous versions. It was the first thing I noticed when I re-loaded the project that contained the last version. My new project loaded quicker, so I decided instead of lowering my polyphony when I shut down, I left them all on 8 voice. Re-Booted and the project loaded much faster, and w/ full polyphony. Kudos to you, however this was achieved.
The color scheme on the EQ's shows up under the glaring reflections and lights also.
Presets are a must, as I believe many people will be using this for recording, and playing.
I now have 3 custom mixers 4 my DAWg's. You and SHARC should be proud, as the other 2 custom mixers are from DAS, and SpaceF. You have come out of the gate with style, speed , and grace.
Hats Off,
JV
Hats Off,
JV
- the19thbear
hi
any chance this mixer will be able to run on 2 boards, each with 3 dsp=6 dsp´s in total?? or is this dreaming?? maybe by bypassing the eq´s and onther goodies...
thanks.
thanks.
Shroomz, I made mix in 48khz project, with 0.1 version, no DSP management. Can you confirm this that device is working on 44.1, please. I am a litle confused about that....Shroomz wrote:Voidar, yes 48khz operation is possible, but not with this device architecture. This was built for use @ 44.1, sorry I should've mentioned that.
- the19thbear
ok
yeah.. i guess you are right.... i just like the GUI of this mixer... but´if the sound is the same i might as well go with the vp 8, thanks.
Shroomz:
I have managed to do something strange.
I set the sample rate for my XTCproject to 44.1K, then load your mixer, set up the connections and disables it from DSP.
I then load up REAPER XTC project loads up while A16U displays 44.1K, but after that I force set the sample rate from REAPER to 48K, the 48K LED on my A16U lights up. I then load the mixer into DSP again and everything loads up fine.
I can play back and load plug-ins (that work) in the host.
If I ever get a DSP error (like when clicking the XTC-icon to see DSP resources), I can just press NO or CANCEL and things will continue to play back, with loaded plugs still processing. If I hit YES (for optimizing) I will go into an unlimed loop of DSP capacity limit reached.
I find this phenomenon quite strange frankly
, especially since the A16U reports the rate set by REAPER. And BTW, if I set rate to 88.K1 or 96K, I will get DSP errors.
BTW, we need patch saving with this mixer.
UPDATE:
If I hook up the midi out connector it won't work. :]
UPDATE:
Re: hi
Hi, there's a new version just uploaded which is called 'VM1242_v0_6_MINdspMAN'. That version should hopefully load on a 2 x 3dsp setup, but I can't test that here, so you'll just need to try it. Let me know how it goes.the19thbear wrote:any chance this mixer will be able to run on 2 boards, each with 3 dsp=6 dsp´s in total?? or is this dreaming?? maybe by bypassing the eq´s and onther goodies...
