BUD'S KEYBOARDS
MASTER KEYBOARDS AND REMOTES   SYNTH WING #1   SYNTH WING #2
Top: Oberheim XK customized
Middle: Yamaha KX76
Bottom: Rhodes MK80
  Yamaha DX7mkIIFD, Oberheim Xpander, MIDI & power rack
Minimoog D customized w/ Roland MPU-101 MIDI/CV unit.
Kurzweil PC361 w/ Ribbon Controller option.  Emagic MT-4 MIDI interface for Apple Powerbook G3 running Emagic Sounddiver v3.
FULL KEYBOARD RIG   RACK GEAR AND YAMAHA KX5   RACK GEAR TOP VIEW
Synth Wing #1 rack content - top to bottom:
  • Custom made MIDI patchpay w/ MIDI multicore connector
  • Miditemp PMM88E MIDI processor matrix switcher 8x8
  • 1HU rack spacer (ventilation)
  • Alesis RA-150 power amp (for Alesis Monitor One mk II passive speakers)
  • T-Racks Power Distributor
Synth Wing #1 Keys & tone generator:
  • Yamaha DX7mkIIFD
  • Oberheim Xpander
Rack left (top view) content - from bottom to top
  • Oberheim DPX-1
  • Akai S-1100
  • 0.5HU rack spacer
  • Roland M-160 Line Mixer 16 Channel
  • MAM KM122 12 Channel Line Mixer
  • Furman PL Plus E line conditioner/ rack light
  •  on top:
  • Akai S-1100 spare machine
Rack right (top view) content - from bottom to top
  • Korg SG Rack
  • Digitech Studio 400 multi FX
  • 0,5HU rack spacer
  • Rolls RM203 Line Mixer 20 input/ 10 stereo channels
  • AKAI MB-76 MIDI controllable audio matrix switcher
  • 0,5HU rack spacer
  • Rack on top: EMU E54 EOS sampler w/int. 500MB HD & 2 SCSI HDs in top case / custom build 2 Ch. DI, transformer balanced
Rack left (bottom view) content - from bottom to top
  • Connex POW power distributor 1HU rack spacer
  • Sycologic M16/ M16X (16x32 MIDI matrix switcher) combo
  • Anatek Studio Merge 8 in 1
  • Behringer 8 channel denoiser for TX-816
  • Yamaha TX-816
  • Kronauer Syndrive (SCSI HD & CD-ROM) for AKAI S-1100
  • Oberheim DPX-1 sample players w/ single out & CD-ROM options (full EMU Emulator II replacements) x 2
  • AKAI S-1100 incl. all option boards
Rack right (bottom view) content - from bottom to top
  • Power distributor behind blind panel
  • Behringer 2-Channel Denoiser
  • Behringer Splitter/Mixer
  • Dynacord DLS-300 Leslie sim
  • Rocktron 300A mono compressor/HUSH II
  • Chandler Tube Driver
  • Rocktron ProChorus
  • Rocktron GAP-1 preamp
  • Roland U220 & D-110 (now again replaced by Roland D550 w/ Musitronics speed kit, multimode & memory expansion
  • Korg M1R ex ROMpler
  • Korg Wavestation SR vector synth
  • Yamaha TG500 ROMpler
  • Yamaha TG77 AFM synth
  • Korg SG Rack Digital Piano module
  • Korg DT-1 Pro tuner
Rocktron GAP-1 and Rocktron ProChorus as 1 block can be addressed by the AKAI MB-76 audio matrix switcher in real-time for screaming lead sounds and run/return to separate input channels of the Roland M-160 Line Mixer w/ 4 aux sends which feed the Digitech Studio 400 multi FX unit.
Same way and via the AKAI MB-76 again, the Leslie simulator block is separately addressable too. This block is in this SPECIAL order:
  • Rocktron 300A Compressor unit > Chandler Tube Driver 19" > Rocktron 300A HUSH II unit > Dynacord DLS300 Leslie simulator.
The application for this is that the Rocktron 300A has separate inputs and outputs for the compressor and the single ended noise reduction.  So it's do-able with only 1 HU unit versus two separate pieces of gear.  And that's why I have it.
I access AKAI MB-76 audio Ins (there are 7) by running DX7mkIIFD audio outs directly to the AKAI MB-76, same with single out #4 of KORG M1R ex and the Minimoog D audio out.  So these three instruments are routable to the effects blocks described above or directly to different or dedicated Roland M-160 Line Mixer input channels, because there are 6 outputs on the AKAI MB-76 (2 mono outputs run to the FX blocks with 4 outputs for DX7mkII FD direct to mixer).  The Minimoog D mono and M1R out #4 mono are connected direct to mixer when FX blocks aren't needed.  All this is switchable by MIDI program change commands transmitted from the Miditemp PMM88E.
Bud Weiser July 2012
